Maya 2011 Export of Sub D's
tazdog
PostPosted: Fri Dec 03, 2010 4:21 pm    Post subject: Maya 2011 Export of Sub D's Reply with quote
Can some one tell me how they have been able to get sub D geometry into UVLayout. The OBJ extension in maya will not export an I assume import Sub D's. Checking UVLayout I did not see another extension that maya has that UVLayout will accept. Embarassed
PostPosted: Fri Dec 03, 2010 5:22 pm    Post subject: Reply with quote
Not sure about Maya 2011, but in every other version of Maya I've used, you put the SUBD surface into polygon proxy mode, then select it and export it. The cage gets saved to the OBJ, and then in UVLayout you load that in with "SUBD" selected.
Or use the Maya transfer plugin here ...
http://www.headus.com/phpbb/viewtopic.php?t=394
It makes the transfer of meshes from and to Maya a lot easier!
tazdog
PostPosted: Fri Dec 03, 2010 8:58 pm    Post subject: Reply with quote
thanks a bunch, will give them both a try
Rasmunda
PostPosted: Thu Dec 16, 2010 8:21 am    Post subject: Reply with quote
Thanks , I will give it a try!
