Posted: Mon May 27, 2019 12:40 am Post subject: UVLayout v2.11.01 now available |
Hello All,
Sorry, some emails went out with the wrong link to
details on the v2.11.02 release. That information is here ...
http://www.headus.com/phpbb/viewtopic.php?t=1679
UVLayout v2.11.01 is now available for all users from ...
- Plugin Script : GUI button presses can be recorded into a
script file, and these can then be played back via the plugin
mode's .cmd file. This means that many of UVLayout's functions
can now be driven by external scripting (e.g. shell packing).
Changes to existing tools:
- Pack Boxes : All tools using boxes (i.e. those in the Group panel
and Pack settings) are now enabled in the Hobbyist/Student version.
- Edit Colors Preference : Added choice for picked shell boundary
color (default black).
- G Paint : Added option under Edit Settings to switch back to
older style G key painting.
Bugs fixed:
- C Hotkey : If multiple display panes were open, edge tagging
in the Ed view wasnt being displayed correctly.
- Display Panes : Moving panes resized them in odd ways.
- Window Resize : On some rare graphics hardware and driver
combinations, resizing the editing window would cause it to die.
UVLayout now runs a test to check for this when it first runs,
and selects an alternate redraw method if the issue is detected.
- Screen Height : When opening up a GUI panel, UVLayout will float
it instead if the normal opening would make the main GUI taller
than the screen height. On OS X and Linux systems, sometimes
the automatic screen height calculation is wrong, so the Screen
Height GUI preference can now be set to the correct value.
- Licensing GUI : Fixed excessive license server scan popup
questioning. Also the "Build Status Report" output was truncated
if many floating licenses where checked out.
