[Blender <> UVLayout ] Bridge
Titus
PostPosted: Tue Dec 05, 2017 1:19 am    Post subject: [Blender <> UVLayout ] Bridge Reply with quote
Hi there!
It's a Blender bridge add-on between two programs Blender and Headus UVLayout for UV maps editing.
Bridge Settings:
- Mode: UVLayout modes Poly or SUBD.
- UV: Editing type, just New or Edit for selected UV channel
- UV channel: Blender's UV map index.
And UVLayout send button.
How to install:
Blender>User Preferences >Add-ons>Install add-on from file>Select uvLayout_Bridge.py
And it will appeared in UV category.
Then you have to make it active and select path to UVLayout.
------Download-----
https://gumroad.com/l/Blender2UVLayoutBridge
Have a nice day and donate if you enjoy it!
PostPosted: Tue Dec 05, 2017 4:21 pm    Post subject: Reply with quote
Thanks for sharing you work on the Blender plugin!
Titus
PostPosted: Wed Dec 06, 2017 7:09 am    Post subject: Reply with quote
You are welcome!
dela
PostPosted: Wed Dec 06, 2017 9:49 am    Post subject: Reply with quote
I tried this but its written for Windows i see. Im trying to get it to work on OSX but im running into issues.
I can get to open using Headus-UVlayout-Pro.app but then nothing happens. When i try to use uvlayout_proc = subprocess.Popen(["/bin/bash","-c","open "+appOpen ,'--args', path + file_Name])
Whee appOpen = '/Applications/headus-UVLayout-Pro.app/Contents/MacOS/uvlayout-plugin' i get a error, "uvlayoutP: Need to define plugin transfer file in args."
How can we pass the arguments to that plugin?
dela
PostPosted: Wed Dec 06, 2017 10:17 am    Post subject: Reply with quote
I got it sort of working but now get errors in the terminal. Ive searched the forum about this OSX issue. Not very clear whats happening. First i thought its due too permission, so i tried hardcoding a different file on the desktop. But still i get this error in below in the terminal.
Code:
arning: translation table syntax error: Unknown keysym name:  osfActivate
Warning: ... found while parsing ':<Key>osfActivate:      ManagerParentActivate()'
Warning: String to TranslationTable conversion encountered errors
Warning: translation table syntax error: Unknown keysym name:  osfBeginLine
Warning: ... found while parsing ':<Key>osfBeginLine:      ManagerGadgetTraverseHome()'
Warning: translation table syntax error: Unknown keysym name:  osfActivate
Warning: translation table syntax error: Unknown keysym name:  osfSelect
Warning: ... found while parsing ':<Key>osfSelect:   ManagerGadgetSelect()'
Warning: ... found while parsing ':<Key>osfSelect:   MenuBarGadgetSelect()'
Warning: translation table syntax error: Unknown keysym name:  osfHelp
Warning: ... found while parsing ':<Key>osfHelp:      MenuHelp()'
Warning: ... found while parsing ':<Key>osfHelp:         ManagerGadgetHelp()'
Warning: ... found while parsing ':<Key>osfActivate:   PrimitiveParentActivate()'
Warning: ... found while parsing ':<Key>osfHelp:      Help()'
Warning: translation table syntax error: Unknown keysym name:  osfCancel
Warning: ... found while parsing ':<Key>osfCancel:   MenuEscape()'
Warning: ... found while parsing ':<Key>osfSelect:   ArmAndActivate()'
Warning: translation table syntax error: Unknown keysym name:  osfPrimaryPaste
Warning: ... found while parsing ':m <Key>osfPrimaryPaste:cut-primary()'
Warning: ... found while parsing ':s c <Key>osfBeginLine:      ListBeginDataExtend()'
Warning: ... found while parsing '<Key>osfCancel:         MenuEscape()'
Warning: ... found while parsing ':<Key>osfSelect:   KeySelect()'
When i load the model manual with that plugin menu open it loads just fine
dela
PostPosted: Wed Dec 06, 2017 1:11 pm    Post subject: Reply with quote
I got it working now in OSX, though i can seem to pass the Poly/subd or Edit / new variables yet. I try to get that working as well.
PS you dont have a check for when nothing is selected. It will export but UVlayout gives error about empty mesh. Ive added a check for that. Now i only need to add a fix for import part.
Titus
PostPosted: Thu Dec 07, 2017 11:16 am    Post subject: Reply with quote
Yep, I think we can dig here http://www.uvlayout.com/doc/Installation_Guide:_OS_X
dela
PostPosted: Thu Dec 07, 2017 11:59 am    Post subject: Reply with quote
It will open the UVlayout but keeps opening in 'regular' modus. only when i run the plugin direct and pass the file does it work. It does catch the arguments because when i add them i get this warning;
Code:
dela
PostPosted: Thu Dec 07, 2017 12:05 pm    Post subject: Reply with quote
What is the tilde (~) icon do in the those panels? When i click it changes to a V, i cant find the meaning of this in the manual
dela
PostPosted: Thu Dec 07, 2017 2:19 pm    Post subject: Reply with quote
Okay it remember panel location, thats handy. Was not in the manual though
