Titus
Posted: Tue Dec 05, 2017 1:19 am Post subject: [Blender <> UVLayout ] Bridge |
Hi there!
It's a Blender bridge add-on between two programs Blender and Headus UVLayout for UV maps editing.
Bridge Settings:
- Mode: UVLayout modes Poly or SUBD.
- UV: Editing type, just New or Edit for selected UV channel
- UV channel: Blender's UV map index.
And UVLayout send button.
How to install:
Blender>User Preferences >Add-ons>Install add-on from file>Select uvLayout_Bridge.py
And it will appeared in UV category.
Then you have to make it active and select path to UVLayout.
------Download-----
https://gumroad.com/l/Blender2UVLayoutBridge
Have a nice day and donate if you enjoy it! |
Posted: Tue Dec 05, 2017 4:21 pm Post subject: |
Thanks for sharing you work on the Blender plugin!
Titus
Posted: Wed Dec 06, 2017 7:09 am Post subject: |
| headus wrote: | Thanks for sharing you work on the Blender plugin!
You are welcome! |
dela
Posted: Wed Dec 06, 2017 9:49 am Post subject: |
I tried this but its written for Windows i see. Im trying to get it to work on OSX but im running into issues.
I can get to open using Headus-UVlayout-Pro.app but then nothing happens. When i try to use uvlayout_proc = subprocess.Popen(["/bin/bash","-c","open "+appOpen ,'--args', path + file_Name])
Whee appOpen = '/Applications/headus-UVLayout-Pro.app/Contents/MacOS/uvlayout-plugin' i get a error, "uvlayoutP: Need to define plugin transfer file in args."
How can we pass the arguments to that plugin? |
dela
Posted: Wed Dec 06, 2017 10:17 am Post subject: |
I got it sort of working but now get errors in the terminal. Ive searched the forum about this OSX issue. Not very clear whats happening. First i thought its due too permission, so i tried hardcoding a different file on the desktop. But still i get this error in below in the terminal.
| Code: | arning: translation table syntax error: Unknown keysym name: osfActivate
Warning: ... found while parsing ':<Key>osfActivate: ManagerParentActivate()'
Warning: String to TranslationTable conversion encountered errors
Warning: translation table syntax error: Unknown keysym name: osfBeginLine
Warning: ... found while parsing ':<Key>osfBeginLine: ManagerGadgetTraverseHome()'
Warning: translation table syntax error: Unknown keysym name: osfActivate
Warning: translation table syntax error: Unknown keysym name: osfSelect
Warning: ... found while parsing ':<Key>osfSelect: ManagerGadgetSelect()'
Warning: ... found while parsing ':<Key>osfSelect: MenuBarGadgetSelect()'
Warning: translation table syntax error: Unknown keysym name: osfHelp
Warning: ... found while parsing ':<Key>osfHelp: MenuHelp()'
Warning: ... found while parsing ':<Key>osfHelp: ManagerGadgetHelp()'
Warning: ... found while parsing ':<Key>osfActivate: PrimitiveParentActivate()'
Warning: ... found while parsing ':<Key>osfHelp: Help()'
Warning: translation table syntax error: Unknown keysym name: osfCancel
Warning: ... found while parsing ':<Key>osfCancel: MenuEscape()'
Warning: ... found while parsing ':<Key>osfSelect: ArmAndActivate()'
Warning: translation table syntax error: Unknown keysym name: osfPrimaryPaste
Warning: ... found while parsing ':m <Key>osfPrimaryPaste:cut-primary()'
Warning: ... found while parsing ':s c <Key>osfBeginLine: ListBeginDataExtend()'
Warning: ... found while parsing '<Key>osfCancel: MenuEscape()'
Warning: ... found while parsing ':<Key>osfSelect: KeySelect()'
When i load the model manual with that plugin menu open it loads just fine |
dela
Posted: Wed Dec 06, 2017 1:11 pm Post subject: |
I got it working now in OSX, though i can seem to pass the Poly/subd or Edit / new variables yet. I try to get that working as well.
PS you dont have a check for when nothing is selected. It will export but UVlayout gives error about empty mesh. Ive added a check for that. Now i only need to add a fix for import part. |
Titus
dela
Posted: Thu Dec 07, 2017 11:59 am Post subject: |
It will open the UVlayout but keeps opening in 'regular' modus. only when i run the plugin direct and pass the file does it work. It does catch the arguments because when i add them i get this warning;
| Code: | | uvlayoutP: Need to define plugin transfer file in args. |
dela
Posted: Thu Dec 07, 2017 12:05 pm Post subject: |
| What is the tilde (~) icon do in the those panels? When i click it changes to a V, i cant find the meaning of this in the manual |
dela
Posted: Thu Dec 07, 2017 2:19 pm Post subject: |
| Okay it remember panel location, thats handy. Was not in the manual though |
