miauu
Posted: Thu May 09, 2013 5:10 pm Post subject: |
Thanks for sharing your work with other 3DS users!
miauu
Posted: Thu May 09, 2013 7:46 pm Post subject: |
I hope they will find the script useful.
AnatolM
Posted: Thu Feb 27, 2014 2:41 am Post subject: |
| Nice idea, but during the sending back - UV's are splitted unfortaunatly with this script
haueryou26
Posted: Thu Jun 19, 2014 8:27 am Post subject: UVPipe Script Crash when creating UV Set 2 and 3 |
They Guys, Im using 3d Max 2014 and when i use UV Pipe it seems to work with Uv set 1 but Uv Set 2 and 3 Crash when you send the asset back to max. I attached the Script crash. Any Ideas how to fix this?
| Description: |
| Filesize: |
140.41 KB |
| Viewed: |
70027 Time(s) |
zig113
Posted: Fri Sep 26, 2014 9:16 am Post subject: Getting an error running plugin with Max 2015 |
Plugin doesnt seem to want to work with 3dsmax 2015, any help would be appreciated.
-Z
| Description: |
| Filesize: |
92.82 KB |
| Viewed: |
68517 Time(s) |
Asimov
Posted: Sat Apr 04, 2015 9:38 am Post subject: Max 2015 |
I am using max 2015 and when I send the uvs back to max they look ok in the uv editor, but if I add a checkerboard pattern to my model they are stretched and squashed all over the place in 3ds max and yet the check pattern in uvlayout is fine.
Would love to see this working properly. it will be the difference between me buying headus and not buying.
angel_a
Posted: Fri Dec 09, 2016 8:30 am Post subject: Stretched unwrap in 3ds max 2011 |
| Hi! I use 3ds max 2011 and this plugin, while testing headus. But after I revert (send back) unwrapped model to 3ds max - it is streched, distorted. Only way I managed to do - saving obj from headus. It is not what I expected. Can this be fixed?
