OBJ with UV not working at load
SuperSheep
PostPosted: Thu Aug 09, 2012 4:45 pm    Post subject: OBJ with UV not working at load Reply with quote
Can UV Layout, load a OBJ file that contains UV's ? I read the docs, and from my understanding it should be able too, after tinkering with some of the load options, I was able to get my OBJ object to load, but not with the UV that it contained ?
PostPosted: Thu Aug 09, 2012 5:21 pm    Post subject: Reply with quote
Select "Edit" in the load options ... that should load your OBJ with all existing UVs retained.
SuperSheep
PostPosted: Thu Aug 09, 2012 5:34 pm    Post subject: Reply with quote
Before posted, that is one of the options I tried, didn't work.
PostPosted: Thu Aug 09, 2012 5:37 pm    Post subject: Reply with quote
If you can email me that OBJ then I'll try and work out why its not loading properly.
SuperSheep
PostPosted: Thu Aug 09, 2012 8:07 pm    Post subject: Reply with quote
It's working, thank you Smile
