SuperSheep
Posted: Thu Aug 09, 2012 4:45 pm Post subject: OBJ with UV not working at load |
Can UV Layout, load a OBJ file that contains UV's ? I read the docs, and from my understanding it should be able too, after tinkering with some of the load options, I was able to get my OBJ object to load, but not with the UV that it contained ? |
Posted: Thu Aug 09, 2012 5:21 pm Post subject: |
Select "Edit" in the load options ... that should load your OBJ with all existing UVs retained.
SuperSheep
Posted: Thu Aug 09, 2012 5:34 pm Post subject: |
headus wrote: | Select "Edit" in the load options ... that should load your OBJ with all existing UVs retained.
Before posted, that is one of the options I tried, didn't work. |
Posted: Thu Aug 09, 2012 5:37 pm Post subject: |
If you can email me that OBJ then I'll try and work out why its not loading properly.
SuperSheep
Posted: Thu Aug 09, 2012 8:07 pm Post subject: |
headus wrote: | If you can email me that OBJ then I'll try and work out why its not loading properly.
It's working, thank you  |
