Eisenhower
Posted: Mon Oct 11, 2010 10:06 pm Post subject: Obj file has 4x's the ploys :( |
| Hi, I'm using the demo of uvlayout and so far this tool is HOT! However.... I work in cinema 4d R10 and exported a model that has 2698 polys to obj. I setup the uvs in layout and export back to obj. By the time I open it in cinema, it's now over 10 thousand polys.... I'm using skin props obj exporter plugin. Is there something I can do in either app. to maintain the original poly count? |
Posted: Mon Oct 11, 2010 10:52 pm Post subject: |
UVLayout doesn't modify the geometry, so I'd say it was the OBJ export/import stage in Cinema 4d that's doing the damage. Check any options you have in the export/import plugin; maybe you have something ticked that's duplicating or subdividing faces?
Eisenhower
Posted: Tue Oct 12, 2010 3:31 am Post subject: |
| Well that's a start, thanks |
