Posted: Wed Feb 17, 2010 12:41 pm Post subject: shift \ and rotate shell within a box |
what is shift \ ? It brings up a blue arrow pointing up.
Also is there a way to rotate a shell or multiple shells that are within a box?
One other thing that had me puzzled, how do I unhide all hidden polys?
Nothing on the hide menu work for me. Had to start again. |
Posted: Wed Feb 17, 2010 6:15 pm Post subject: Re: shift \ and rotate shell within a box |
"what is shift \ ? It brings up a blue arrow pointing up."
It stops those shells from being rotated if you have "Rotate" turned on in the Pack tool.
"Also is there a way to rotate a shell or multiple shells that are within a box?"
Yes, sort of ... you have to put them into their own sub-box though.
"how do I unhide all hidden polys?"
H-U should be doing it.
Posted: Wed Feb 17, 2010 6:44 pm Post subject: rotate sub box |
yeah I have tried that but its a bit fiddly, if there was a hot hey to assign a box to selected shells it would make it easier. If there is only a few I drag them out of the box, rotate the put back in the box.
I was thinking ctrl or shift-\ could be assigned to rotate a shell within a box..
What do you think?
M |
Posted: Wed Feb 17, 2010 6:58 pm Post subject: Re: rotate sub box |
" ctrl or shift-\ could be assigned to rotate a shell within a box.."
OK, that should be easy enough. Shift-\ is taken (that's the "|" to lock shell orientations), but Ctrl-\ is free.
SuperSheep
Posted: Wed Jan 23, 2013 9:22 pm Post subject: Re: rotate sub box |
| headus wrote: | " ctrl or shift-\ could be assigned to rotate a shell within a box.."
This command does nothing, should should it do ? |
