Enabling Ed View
bigbrainz
PostPosted: Fri Apr 13, 2007 9:10 am    Post subject: Enabling Ed View Reply with quote
Very cool tool--for some reason I can't figure out how to enable Ed View. I included a pic so you can see how I'm going about it. The "Ed" button is clicked, but I still get an error when I try to move the shells out of the way.
Also, it seems that I can only rotate the mesh towards me or away from me 180 degrees, making it hard to work on the top of its head. Is that something I can unlock? Thanks!
moochie
PostPosted: Fri Apr 13, 2007 3:25 pm    Post subject: Reply with quote
Hi. You're in Edit view, but you're trying to move the mesh using Space & LMB (or RMB). To move shells, it's Space & MMB (Middle Mouse Button). The error message means you can only move split-off shells (ie not rotate or resize) when you're in Edit mode. It doesn't mean you're not in Edit mode (though the message is a bit ambiguous, isn't it?). Maybe Phil should consider rewording the error as 'You can only move shells in this view'?
To free rotate, click the '-' button next to Up in the Display palette. Maybe Phil should call this button '360' or 'Free', if there's room on the button?
bigbrainz
PostPosted: Fri Apr 13, 2007 3:32 pm    Post subject: Reply with quote
Ah, very easy--thanks!
PostPosted: Fri Apr 13, 2007 5:43 pm    Post subject: Reply with quote
Will do! I'm about to upload v1.18, so it should make it into that release.
It is a bit tight there ... I'll think about it :-)
twocust
PostPosted: Sat Apr 14, 2007 9:26 am    Post subject: Reply with quote
would lowercase 'r' be confusing? (for rotate)
PostPosted: Sat Apr 14, 2007 5:33 pm    Post subject: Reply with quote
Actually I managed to squeeze "Free" in OK. You'll see it in the next release, as soon as I stop finding that one last bug in the new Undo code!
moochie
PostPosted: Sun Apr 15, 2007 3:44 am    Post subject: Reply with quote
Ooo .. new undo code, eh? Will it (I presume Ctrl+Z) undo whatever your last action was, or only certain actions?
Lewi
PostPosted: Sun Apr 15, 2007 4:49 am    Post subject: Reply with quote
Its seems weird but I dont really miss undo anymore. Its made me more carefull with the hotkeys and locking shells, but it wiil definitely make me feel better knowing its there if I need it though.
PostPosted: Sun Apr 15, 2007 7:00 pm    Post subject: Reply with quote
Yep, Ctrl-Z, and it undoes probably about 90% of anything you might do. Things like the H hide menu and 1/2/3 view toggling are considered too simple. All the "oh damn, I just messed everything up" type actions are undoable though.
