Stack problem in latest version
dorkati
PostPosted: Sun Feb 18, 2007 9:52 am    Post subject: Stack problem in latest version Reply with quote
Until this I never used stack...just wished to try, because saw in one of movies, but if I click on stack after set s point on 2 shells, nothing happen. Checked movie again, made everything how needed and still not work..
same with double s
Tried as I see on video 16, but not work Sad
moochie
PostPosted: Sun Feb 18, 2007 3:50 pm    Post subject: Reply with quote
Double S and Stacking work fine here.
I notice you've changed the orientation of loading models, Phil. Good job too .. I always had to use the Y option under Display to view models properly .. now I don't. Very Happy
PostPosted: Sun Feb 18, 2007 5:29 pm    Post subject: Re: Stack problem in latest version Reply with quote
dorkati wrote:
...but if I click on stack after set s point on 2 shells, nothing happen.
Do the two shells have the same number of edges around their boundaries? If they don't, they wont stack. The Gather U button will gather together all shells with matching boundaries, then you can clearly see whats stackable.
PostPosted: Sun Feb 18, 2007 5:36 pm    Post subject: Reply with quote
No, but probably whats happening is that UVLayout now remembers the Up axis setting between sessions; if you set it to Y it'll stay that way until you change it to something else.
dorkati
PostPosted: Mon Feb 19, 2007 3:57 am    Post subject: Reply with quote
I will check...actually these are arms for a top, but I didn't mirror them so maybe not exactly.
Will check and will tell you, thanks .
dorkati
PostPosted: Mon Feb 19, 2007 4:24 am    Post subject: Reply with quote
Checked...exactly same number vertices, edges, faces.
And double s should be work anyway Sad
PostPosted: Mon Feb 19, 2007 5:50 pm    Post subject: Reply with quote
Are you able to email me that mesh? Zip up the UVL file and send it over and
I'll take a look at the arms that wont stack.
