dorkati
Posted: Sun Feb 18, 2007 9:52 am Post subject: Stack problem in latest version |
Until this I never used stack...just wished to try, because saw in one of movies, but if I click on stack after set s point on 2 shells, nothing happen. Checked movie again, made everything how needed and still not work..
same with double s
Tried as I see on video 16, but not work  |
moochie
Posted: Sun Feb 18, 2007 3:50 pm Post subject: |
Double S and Stacking work fine here.
I notice you've changed the orientation of loading models, Phil. Good job too .. I always had to use the Y option under Display to view models properly .. now I don't.  |
Posted: Sun Feb 18, 2007 5:29 pm Post subject: Re: Stack problem in latest version |
| dorkati wrote: | | ...but if I click on stack after set s point on 2 shells, nothing happen. |
Do the two shells have the same number of edges around their boundaries? If they don't, they wont stack. The Gather U button will gather together all shells with matching boundaries, then you can clearly see whats stackable.
Posted: Sun Feb 18, 2007 5:36 pm Post subject: |
| moochie wrote: | | I notice you've changed the orientation of loading models, |
No, but probably whats happening is that UVLayout now remembers the Up axis setting between sessions; if you set it to Y it'll stay that way until you change it to something else.
dorkati
Posted: Mon Feb 19, 2007 3:57 am Post subject: |
I will check...actually these are arms for a top, but I didn't mirror them so maybe not exactly.
Will check and will tell you, thanks . |
dorkati
Posted: Mon Feb 19, 2007 4:24 am Post subject: |
Checked...exactly same number vertices, edges, faces.
And double s should be work anyway  |
Posted: Mon Feb 19, 2007 5:50 pm Post subject: |
Are you able to email me that mesh? Zip up the UVL file and send it over and
I'll take a look at the arms that wont stack.
