unwrapuser
Posted: Sun Jun 06, 2010 1:25 am Post subject: flipped uv texture |
| After using segment to unwrap a non organic object , i check the texture by using the numbered texture it shows that is upside down, is this a problem? how can i go about fixing this? |
Posted: Mon Jun 07, 2010 7:15 pm Post subject: |
If the numbers appear up-side down, its not necessarily a bad thing, it just means that when painting the texture into the map it also need to be up-side down.
If you want to fix it you just have to rotate those shells by 180 degrees; the easiest way to do that is with the back-slash '\' hotkey. Tap it twice over the offending shells.
