Polygroups?
arkasa
PostPosted: Tue Jan 26, 2010 8:35 am    Post subject: Polygroups? Reply with quote
I'm making my obj in maya with polygroups. When i produce a UVtexture in UVL it apparently ignores my polygroups and exports as a single mesh. Can i fix this?
PostPosted: Tue Jan 26, 2010 9:48 pm    Post subject: Reply with quote
When you're saving your mesh out of UVLayout, the "Update" button instead of the "Save". You select the original OBJ that you exported from maya, and UVLayout makes a copy of that with all the grouping info intact, and only changes the UVs.
arkasa
PostPosted: Wed Jan 27, 2010 4:35 am    Post subject: Reply with quote
thanks phil, i tried out the maya plugin in 2010 and that seems to fix the problem as well!
Greetings from icecold Belgium Smile
PostPosted: Wed Jan 27, 2010 6:41 pm    Post subject: Reply with quote
Great!
And greetings from sunny Perth, with a forecast of 35C max here today :-)
