TheSnap
Posted: Fri Oct 02, 2009 6:20 am Post subject: Demo Version on Mac is crashing |
Hi there,
I just discovered your software and was happy to find a UV-solution that seems to support the Mac.
So I tried to load the trial-version you offer (thank you)
Unfortunately it does not work, neither on my MacBook (OSX 10.5.5) nor on my MacPro (OSX 10.5.6)
That´s a pity. Any help for me?
Thanks and greetings from Germany,
Stephan |
Posted: Fri Oct 02, 2009 5:27 pm Post subject: |
Are any error message being displayed? We recently updated our development build machine, so something might be missing from the install files still.
TheSnap
Posted: Mon Oct 05, 2009 12:22 am Post subject: Error Message |
thanks for your reply.
The error message I receive is the »an unexpected error has occured« (I hope I translated this correct from german to english)
Since your server seems to be stressed this morning (yes, here is a fine sunny mornig!), I cannot try again.
I will try again and give you feedback.
Thanks a lot,
Stephan
UV Layout seems a very helpful tool - is it possible to buy it on another way, cause I don´t have any credit card? |
TheSnap
Posted: Mon Oct 05, 2009 12:28 am Post subject: Again |
I tried again the version, you posted the bygone friday. The same problem, unexpected error. It´s a pity.
If it helps, here the text from the computer´s bug report:
Process: headus [515]
Path: /Volumes/headus-UVLayout-Demo-Installer/headus-UVLayout-Demo.app/Contents/MacOS/bin/headus
Identifier: headus
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: launchd [1]
Date/Time: 2009-10-05 10:25:30.268 +0200
OS Version: Mac OS X 10.5.6 (9G55)
Report Version: 6
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Library not loaded: /opt/local/lib/libXt.6.dylib
Referenced from: /Volumes/headus-UVLayout-Demo-Installer/headus-UVLayout-Demo.app/Contents/MacOS/bin/headus
Reason: image not found
Greetings, Stephan |
Posted: Mon Oct 05, 2009 1:02 am Post subject: |
Thanks!
This is the critical info ...
Actually, I've just repartitioned my one OS X system so I can load a totally clean OS (i.e. one not loaded with additional development resources). That's nearly complete, and then hopefully I install the Demo and get the same errors.
Posted: Mon Oct 05, 2009 4:04 am Post subject: |
Fixed I think! The new Demo installer has been uploaded, and it ran OK on a totally clean out-of-the-box install of OS X 10.5 Leopard.
By the way, another part of your error message suggests you might be trying to run UVLayout from inside the DMG file. You need to drag'n'drop the UVLayout package into the Applications folder link, and then run it from your Applications folder.
TheSnap
Posted: Mon Oct 05, 2009 5:23 am Post subject: Juhu (that is: Yahoo) |
it works, prima!
It seems, there is another little bug: when I try to navigate for saving, the save-window freezes, if I go to another level of my hard disk.
Thanks and have a good time,
Stephan |
Posted: Mon Oct 05, 2009 6:05 pm Post subject: |
" the save-window freezes "
I've seen it do that when trying to access a networked folder that's no longer online. Eventually (after a minute) it should give up and unfreeze. Does this sound like your situation?
TheSnap
Posted: Tue Oct 06, 2009 1:59 am Post subject: Window freezes |
not really, it does´nt give up after a minute, it keeps on freezing. The program does not really crash, because I can quit it on the normal way, but the frozen window does´nt disappear.
If it helps: it seems, that the freezing appears, if I click in the free space beneath a directory description, for example: my upmost directory is only a slash »/«.
If I click right in the slash, everything is o.k., but if I click the space right near the slash, but do not hit it, the window freezes.
Hope it will help you,
Greetings,
Stephan |
Posted: Tue Oct 06, 2009 2:50 am Post subject: |
Thanks for the explanation! I'll have a go at finding and fixing that bug tomorrow.
TheSnap
Posted: Wed Oct 14, 2009 12:18 am Post subject: Tomorrow? |
when will be »tomorrow«?
Greetings, Stephan
P.S.: Don´t take that too serious I know, that programming sometimes drives you crazy.
But I would like to buy a version, and it should run in a good manner. |
Posted: Wed Oct 14, 2009 1:03 am Post subject: |
Sorry, bigger fires erupted that needed putting out first :-) Are you per chance running UVLayout under OS X 10.6? That's where I saw the freezing up thing happening here, but it seemed to work fine under 10.5.
