Demo Version on Mac is crashing
TheSnap
PostPosted: Fri Oct 02, 2009 6:20 am    Post subject: Demo Version on Mac is crashing Reply with quote
Hi there,
I just discovered your software and was happy to find a UV-solution that seems to support the Mac.
So I tried to load the trial-version you offer (thank you)
Unfortunately it does not work, neither on my MacBook (OSX 10.5.5) nor on my MacPro (OSX 10.5.6)
That´s a pity. Any help for me?
Thanks and greetings from Germany,
Stephan
PostPosted: Fri Oct 02, 2009 5:27 pm    Post subject: Reply with quote
Are any error message being displayed? We recently updated our development build machine, so something might be missing from the install files still.
TheSnap
PostPosted: Mon Oct 05, 2009 12:22 am    Post subject: Error Message Reply with quote
thanks for your reply.
The error message I receive is the »an unexpected error has occured« (I hope I translated this correct from german to english)
Since your server seems to be stressed this morning (yes, here is a fine sunny mornig!), I cannot try again.
I will try again and give you feedback.
Thanks a lot,
Stephan
UV Layout seems a very helpful tool - is it possible to buy it on another way, cause I don´t have any credit card?
TheSnap
PostPosted: Mon Oct 05, 2009 12:28 am    Post subject: Again Reply with quote
I tried again the version, you posted the bygone friday. The same problem, unexpected error. It´s a pity.
If it helps, here the text from the computer´s bug report:
Process: headus [515]
Path: /Volumes/headus-UVLayout-Demo-Installer/headus-UVLayout-Demo.app/Contents/MacOS/bin/headus
Identifier: headus
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: launchd [1]
Date/Time: 2009-10-05 10:25:30.268 +0200
OS Version: Mac OS X 10.5.6 (9G55)
Report Version: 6
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Library not loaded: /opt/local/lib/libXt.6.dylib
Referenced from: /Volumes/headus-UVLayout-Demo-Installer/headus-UVLayout-Demo.app/Contents/MacOS/bin/headus
Reason: image not found
Greetings, Stephan
PostPosted: Mon Oct 05, 2009 1:02 am    Post subject: Reply with quote
Thanks!
This is the critical info ...
Actually, I've just repartitioned my one OS X system so I can load a totally clean OS (i.e. one not loaded with additional development resources). That's nearly complete, and then hopefully I install the Demo and get the same errors.
PostPosted: Mon Oct 05, 2009 4:04 am    Post subject: Reply with quote
Fixed I think! The new Demo installer has been uploaded, and it ran OK on a totally clean out-of-the-box install of OS X 10.5 Leopard.
By the way, another part of your error message suggests you might be trying to run UVLayout from inside the DMG file. You need to drag'n'drop the UVLayout package into the Applications folder link, and then run it from your Applications folder.
TheSnap
PostPosted: Mon Oct 05, 2009 5:23 am    Post subject: Juhu (that is: Yahoo) Reply with quote
it works, prima!
It seems, there is another little bug: when I try to navigate for saving, the save-window freezes, if I go to another level of my hard disk.
Thanks and have a good time,
Stephan
PostPosted: Mon Oct 05, 2009 6:05 pm    Post subject: Reply with quote
" the save-window freezes "
I've seen it do that when trying to access a networked folder that's no longer online. Eventually (after a minute) it should give up and unfreeze. Does this sound like your situation?
TheSnap
PostPosted: Tue Oct 06, 2009 1:59 am    Post subject: Window freezes Reply with quote
not really, it does´nt give up after a minute, it keeps on freezing. The program does not really crash, because I can quit it on the normal way, but the frozen window does´nt disappear.
If it helps: it seems, that the freezing appears, if I click in the free space beneath a directory description, for example: my upmost directory is only a slash »/«.
If I click right in the slash, everything is o.k., but if I click the space right near the slash, but do not hit it, the window freezes.
Hope it will help you,
Greetings,
Stephan
PostPosted: Tue Oct 06, 2009 2:50 am    Post subject: Reply with quote
Thanks for the explanation! I'll have a go at finding and fixing that bug tomorrow.
TheSnap
PostPosted: Wed Oct 14, 2009 12:18 am    Post subject: Tomorrow? Reply with quote
when will be »tomorrow«?
Greetings, Stephan
P.S.: Don´t take that too serious Smile I know, that programming sometimes drives you crazy.
But I would like to buy a version, and it should run in a good manner.
PostPosted: Wed Oct 14, 2009 1:03 am    Post subject: Reply with quote
Sorry, bigger fires erupted that needed putting out first :-) Are you per chance running UVLayout under OS X 10.6? That's where I saw the freezing up thing happening here, but it seemed to work fine under 10.5.
