Madin
Posted: Mon Aug 03, 2009 1:24 pm Post subject: Related to UVlayout |
Exporting a model and saving it has a OBJ, and then importing that saved model doubles the polygon count. Adding an edit poly modifier reduces the count, but I'm still left with a number of extra polygons, where Max 9 has decided to play a game of 'join the vertices'.
Obviously I can manually remove the extra edges created by Max, but that time spent is reducing the time saved by UVlayout.
Is this a max thing? Clearly this is not a problem with UVlayout, but with how max treats .OBJ files.
Is there any work around? What am I doing wrong? |
Posted: Mon Aug 03, 2009 8:53 pm Post subject: |
I'd have a look at the Max plugin ...
It handles the import/export of OBJs for you, and though I haven't used it myself, would expect it to have all the settings sorted out.
Madin
Posted: Tue Aug 04, 2009 2:19 am Post subject: |
| Thanks I'll give this a go. It would appear from one of the replies on that thread that the extra edges is just a Max 9 import thing. |
r_knightly
Posted: Thu Aug 13, 2009 8:08 am Post subject: |
| In you OBJ exporter change the drop down 'Faces' from triangles to polygons. Max is triangulating your mesh |
