Display problem on OSX
Goto page 1, 2, 3, 4  Next
cali3d
PostPosted: Sun May 10, 2009 5:34 am    Post subject: Display problem on OSX Reply with quote
I have this annoying display problem on OSX 10.5.6 where UVlayout doesnt update the display when i.e. dropping to UV editor..
It turns out like this:
Cut to make a shell.
Hit return on the shell to detach it.
Cut it open (Shift-S)
and Drop it with "D"
The model dosent disappear form the Editor view, until I do a slight camera change.
The same issue happens in the UV editor, when I weld edges, and hit return on a shell to merge them.. It doesnt actually display as merged until the slight view change..
If you want more info, please let me know.
View user's profile Send private message MSN Messenger
PostPosted: Sun May 10, 2009 9:05 pm    Post subject: Reply with quote
I have seen that occasionally, but not consistently. But you're getting it all the time, is that correct?
cali3d
PostPosted: Mon May 11, 2009 12:43 am    Post subject: Reply with quote
That is correct.
Also when de-selecting, and detaching shells (with return) in the UV editor, the shell is displayed as detached when I do a slight zoom.
Btw, I have the hobbyist version, I cant tell if its the same with the other versions.
PostPosted: Mon May 11, 2009 1:09 am    Post subject: Reply with quote
OK, I'll have a look at this in the next few days. I was hoping to do an update by the end of the week anyway, so the fix will be included in that.
cali3d
PostPosted: Mon May 11, 2009 11:16 am    Post subject: Reply with quote
That would be amazing.. If you need me to do some tests "in-between" feel free to contact me.
cgbeige
PostPosted: Wed May 20, 2009 6:19 pm    Post subject: Reply with quote
I'm seeing this consistently too. It seems to have got worse since I upgraded to 10.5.7 and the latest X11.
PostPosted: Thu May 21, 2009 2:41 am    Post subject: Reply with quote
There's new Pro and Hobbyist version installers for OS X on the uvlayout.com Support Extras page; you'll need to login with your License ID to access the page. Let me know if that doesn't or doesn't fix the display problems.
cali3d
PostPosted: Thu May 21, 2009 8:41 am    Post subject: Reply with quote
It seems to be working fine at first glance Smile
Thank you a ton!!
PostPosted: Thu May 21, 2009 5:27 pm    Post subject: Reply with quote
Excellent!
cgbeige
PostPosted: Tue May 26, 2009 7:26 pm    Post subject: Reply with quote
hmmmm. I still get the refresh bug. ATI 4870 (Apple retail - not hacked) and Nehalem Mac Pro. See the attached file. If I hit undo, I have to zoom in to see the change.
PostPosted: Tue May 26, 2009 10:01 pm    Post subject: Reply with quote
Thanks for the bug report ... its possible I forgot to apply the fix to the undo code! I'm away from the office today, but will be able to look at this tomorrow.
cgbeige
PostPosted: Wed May 27, 2009 1:54 pm    Post subject: Reply with quote
great - thanks Phil
PostPosted: Fri May 29, 2009 2:52 am    Post subject: Reply with quote
I've tried a number of different undos and all of them redrew OK here. Is it *all* undos that aren't working for you, or a specific one (e.g. undoing a shell drop)?
cgbeige
PostPosted: Mon Jun 08, 2009 3:49 pm    Post subject: Reply with quote
it's hard to say - it just seems to stop working at some stage. I just extended a green cut and when I undid it, the problem showed up (didn't refresh). This is with the latest version
PostPosted: Mon Jun 08, 2009 8:25 pm    Post subject: Reply with quote
"it just seems to stop working at some stage."
OK, so it sounds like it works initially, yes? In my testing I've just played around for a few minutes, and everything was fine. Its looking like the bug appears after a while, so I'll need to so some more extended playing around.
Page 1 of 4
