cali3d
Posted: Sun May 10, 2009 5:34 am Post subject: Display problem on OSX |
I have this annoying display problem on OSX 10.5.6 where UVlayout doesnt update the display when i.e. dropping to UV editor..
It turns out like this:
Cut to make a shell.
Hit return on the shell to detach it.
Cut it open (Shift-S)
and Drop it with "D"
The model dosent disappear form the Editor view, until I do a slight camera change.
The same issue happens in the UV editor, when I weld edges, and hit return on a shell to merge them.. It doesnt actually display as merged until the slight view change..
If you want more info, please let me know. |
Posted: Sun May 10, 2009 9:05 pm Post subject: |
I have seen that occasionally, but not consistently. But you're getting it all the time, is that correct?
cali3d
Posted: Mon May 11, 2009 12:43 am Post subject: |
That is correct.
Also when de-selecting, and detaching shells (with return) in the UV editor, the shell is displayed as detached when I do a slight zoom.
Btw, I have the hobbyist version, I cant tell if its the same with the other versions. |
Posted: Mon May 11, 2009 1:09 am Post subject: |
OK, I'll have a look at this in the next few days. I was hoping to do an update by the end of the week anyway, so the fix will be included in that.
cali3d
Posted: Mon May 11, 2009 11:16 am Post subject: |
| That would be amazing.. If you need me to do some tests "in-between" feel free to contact me. |
cgbeige
Posted: Wed May 20, 2009 6:19 pm Post subject: |
| I'm seeing this consistently too. It seems to have got worse since I upgraded to 10.5.7 and the latest X11. |
Posted: Thu May 21, 2009 2:41 am Post subject: |
There's new Pro and Hobbyist version installers for OS X on the uvlayout.com Support Extras page; you'll need to login with your License ID to access the page. Let me know if that doesn't or doesn't fix the display problems.
cali3d
Posted: Thu May 21, 2009 8:41 am Post subject: |
It seems to be working fine at first glance
Thank you a ton!! |
Posted: Thu May 21, 2009 5:27 pm Post subject: |
Excellent!
cgbeige
Posted: Tue May 26, 2009 7:26 pm Post subject: |
| hmmmm. I still get the refresh bug. ATI 4870 (Apple retail - not hacked) and Nehalem Mac Pro. See the attached file. If I hit undo, I have to zoom in to see the change. |
Posted: Tue May 26, 2009 10:01 pm Post subject: |
Thanks for the bug report ... its possible I forgot to apply the fix to the undo code! I'm away from the office today, but will be able to look at this tomorrow.
cgbeige
Posted: Wed May 27, 2009 1:54 pm Post subject: |
| great - thanks Phil |
Posted: Fri May 29, 2009 2:52 am Post subject: |
I've tried a number of different undos and all of them redrew OK here. Is it *all* undos that aren't working for you, or a specific one (e.g. undoing a shell drop)?
cgbeige
Posted: Mon Jun 08, 2009 3:49 pm Post subject: |
| it's hard to say - it just seems to stop working at some stage. I just extended a green cut and when I undid it, the problem showed up (didn't refresh). This is with the latest version |
Posted: Mon Jun 08, 2009 8:25 pm Post subject: |
"it just seems to stop working at some stage."
OK, so it sounds like it works initially, yes? In my testing I've just played around for a few minutes, and everything was fine. Its looking like the bug appears after a while, so I'll need to so some more extended playing around.
