tntman
Posted: Wed Nov 26, 2008 2:58 am Post subject: Importing/bringing UVs into UVLayout |
| I use version 2.00.05 of UVLayout in combination with Maya 8.5 with the plugin for fast export back and forth. I am wondering if it's possible to keep/bring with UVs on a object into UVLayout, for example when I just need to tweak some UVs not redo them completely. |
Posted: Wed Nov 26, 2008 3:43 pm Post subject: |
Yes, in the Load Options window you have the choice between "Edit" and "New". If you select "Edit", then UVLayout will load the mesh with its existing UVs.
axia777
Posted: Fri Apr 03, 2009 3:00 pm Post subject: |
| Never mind, I solved the issue.... |
