Importing/bringing UVs into UVLayout
tntman
PostPosted: Wed Nov 26, 2008 2:58 am    Post subject: Importing/bringing UVs into UVLayout Reply with quote
I use version 2.00.05 of UVLayout in combination with Maya 8.5 with the plugin for fast export back and forth. I am wondering if it's possible to keep/bring with UVs on a object into UVLayout, for example when I just need to tweak some UVs not redo them completely.
PostPosted: Wed Nov 26, 2008 3:43 pm    Post subject: Reply with quote
Yes, in the Load Options window you have the choice between "Edit" and "New". If you select "Edit", then UVLayout will load the mesh with its existing UVs.
axia777
PostPosted: Fri Apr 03, 2009 3:00 pm    Post subject: Reply with quote
Never mind, I solved the issue....
