Local Scale>Undrop>ReDrop>Flatten. Bug!
PrayingMantis
PostPosted: Fri Oct 12, 2007 11:47 pm    Post subject: Local Scale>Undrop>ReDrop>Flatten. Bug! Reply with quote
Ok, I got a bug with the procedure I wrote in the title.
If I do a local scale on a shell, than I undrop my shell, and I Redrop it to reflatten it, It can't layout it properly, the shell is always blue and try to search the best layout without getting it. Wink
PostPosted: Sun Oct 14, 2007 5:14 pm    Post subject: Reply with quote
Oops, bug confirmed! I'll have it fixed by the next release.
In the meantime you can work-around the problem by saving your mesh out to a UVL file (e.g. use one of the Tmp buttons), load that file back in, then the affected shells will flatten out correctly.
Update: Bug has been found and corrected, so the fix will be in the next release.
PrayingMantis
PostPosted: Mon Oct 15, 2007 12:53 am    Post subject: Reply with quote
Thank you for your quick answer and for having already resolve this bug and for the tip Wink
PostPosted: Mon Oct 15, 2007 8:26 pm    Post subject: Reply with quote
Fixed! See http://www.headus.com/phpbb/viewtopic.php?p=2410#2410 for details.
