PrayingMantis
Posted: Fri Oct 12, 2007 11:47 pm Post subject: Local Scale>Undrop>ReDrop>Flatten. Bug! |
Ok, I got a bug with the procedure I wrote in the title.
If I do a local scale on a shell, than I undrop my shell, and I Redrop it to reflatten it, It can't layout it properly, the shell is always blue and try to search the best layout without getting it.  |
Posted: Sun Oct 14, 2007 5:14 pm Post subject: |
Oops, bug confirmed! I'll have it fixed by the next release.
In the meantime you can work-around the problem by saving your mesh out to a UVL file (e.g. use one of the Tmp buttons), load that file back in, then the affected shells will flatten out correctly.
Update: Bug has been found and corrected, so the fix will be in the next release. |
PrayingMantis
Posted: Mon Oct 15, 2007 12:53 am Post subject: |
Thank you for your quick answer and for having already resolve this bug and for the tip  |
