Are there plans to develop a plugin for 3ds Max?
EnigmaMachine
PostPosted: Thu Aug 24, 2006 4:31 am    Post subject: Reply with quote
This sounds helpful. Are there plans to develop a plugin for 3ds Max?
PostPosted: Thu Aug 24, 2006 5:34 pm    Post subject: Reply with quote
EnigmaMachine wrote:
... Are there plans to develop a plugin for 3ds Max?
Not by me ... not because I dont want to, but I can only manage time-wise to support one package (ie Maya). But hopefully by providing the interface information, someone can write one and post it here for others to use!
By the way, I should be releasing v1.14 (the version that supports all of this) later today.
Gogitason
PostPosted: Mon May 07, 2007 6:19 pm    Post subject: Reply with quote
Has anyone been able to write a plugin for max?
dfx
PostPosted: Thu Jun 21, 2007 7:59 pm    Post subject: Reply with quote
i'd like to see a plug for max also.
Vincent d izo
PostPosted: Wed Jun 27, 2007 6:20 am    Post subject: Reply with quote
i begin to devlop it, it's work good, but need some optimisation before post it.
see a short video here : http://files-upload.com/fr/327987/uvbridge.wmv.html
Edit by headus : A copy on our server is here ... http://www.headus.com/au/uvlayout/tmp/download/uvbridge.wmv
EnigmaMachine
PostPosted: Wed Jun 27, 2007 9:39 am    Post subject: Reply with quote
Vincent, that looks excellent!
It appears simple to use. It will be much nicer than importing/exporting back and forth all of the time.
I look forward to when you can post it. Thank you for your hard work. Very Happy
Vincent d izo
PostPosted: Wed Jun 27, 2007 12:05 pm    Post subject: Reply with quote
thanks, and the interest of the thing is too keep your material and smoothing group.
because i code a fonction for read obj format and take only the mapping from uvlayout out file. i code the export too, so this is not dependant of obj preset in 3d max Smile.
i need to test with older version, because i'm use as a beta tester a prerealease of max.
PostPosted: Wed Jun 27, 2007 7:08 pm    Post subject: Reply with quote
Many thanks from here too for sharing your work on this!
SMcQ
PostPosted: Thu Jun 28, 2007 1:37 am    Post subject: Reply with quote
Will this work with 3DS Max 7?
SMcQ
Gogitason
PostPosted: Thu Jun 28, 2007 2:41 am    Post subject: Reply with quote
Vincent, you're a genius! Very Happy
michaelws
PostPosted: Thu Jul 19, 2007 9:05 am    Post subject: Reply with quote
Looking forward to your plugin for max. The video looked great. Thanks for developing this.
How is the optimization coming along?
Hadesdareal
PostPosted: Thu Aug 16, 2007 2:04 am    Post subject: Reply with quote
HI
Would like to ask if there are any news about this plug in? If you need Beta testers i will be glad to test it!
Hades
UVguy
PostPosted: Sun Feb 24, 2008 11:40 pm    Post subject: Reply with quote
Is there any word on if this plug is stil in development.. I am sure many many many users of UVlayout would be extreamly interested in it.
cristobal
PostPosted: Mon Aug 08, 2011 6:53 am    Post subject: Reply with quote
Count me in on for a beta tester. I would be so down with that!
G Cristobal
3dmaxpro
PostPosted: Wed Oct 12, 2011 2:54 pm    Post subject: Reply with quote
One other option you can always do too is edit it in maya to a point and then convert it to max and you should be good to go.
