nynaeve
Posted: Tue Oct 01, 2013 11:40 am Post subject: resetting the defaults |
Hello
I've been using UV Layout for months and everything worked fine, till last night. I tried to cut some edges and it didn't respond anymore. I press C pointing to an edge and nothing happens. So I wonder, can I reset the default values (just in case something is wrong with the settings)? I looked everywhere and I can't find it if there is an option.
Thanks ^^ |
nynaeve
Posted: Tue Oct 01, 2013 12:56 pm Post subject: |
| Just in case someone else has a similar problem, I re-installed my graphic driver and that fixed the issue. ^^ |
nynaeve
Posted: Fri Oct 04, 2013 1:51 pm Post subject: |
You are absolutely right, indeed it is an ATI Radeon card and I had the Anti Aliasing in Super Sample mode. I forgot I was rendering and editing images the night before I started having problems with the edge picking. I'll keep that in mind. Thanks for answering.  |
