resetting the defaults
nynaeve
PostPosted: Tue Oct 01, 2013 11:40 am    Post subject: resetting the defaults Reply with quote
Hello
I've been using UV Layout for months and everything worked fine, till last night. I tried to cut some edges and it didn't respond anymore. I press C pointing to an edge and nothing happens. So I wonder, can I reset the default values (just in case something is wrong with the settings)? I looked everywhere and I can't find it if there is an option.
Thanks ^^
nynaeve
PostPosted: Tue Oct 01, 2013 12:56 pm    Post subject: Reply with quote
Just in case someone else has a similar problem, I re-installed my graphic driver and that fixed the issue. ^^
PostPosted: Tue Oct 01, 2013 7:20 pm    Post subject: Reply with quote
Is it an ATI Radeon card? If yes, maybe the note here might help ...
http://www.uvlayout.com/doc/Installation_Guide:_Windows#Known_Problems
nynaeve
PostPosted: Fri Oct 04, 2013 1:51 pm    Post subject: Reply with quote
You are absolutely right, indeed it is an ATI Radeon card and I had the Anti Aliasing in Super Sample mode. I forgot I was rendering and editing images the night before I started having problems with the edge picking. I'll keep that in mind. Thanks for answering. Smile
