Edges one at a time ?
SuperSheep
PostPosted: Sat Jun 23, 2012 7:55 pm    Post subject: Edges one at a time ? Reply with quote
Can I prevent the C key from selecting edge loops and instead select one edge at a time ?
oesponda
PostPosted: Wed Jul 25, 2012 5:00 pm    Post subject: Reply with quote
Use the "0" button under the Edit section
PostPosted: Wed Jul 25, 2012 6:09 pm    Post subject: Reply with quote
Or in the latest release (v2.08.00) you can set it to the new "D" mode. Press and release the C key to select one edge, or press and hold to select the first edge, then drag the mouse pointer to expand the selection in whatever direction you want.
SuperSheep
PostPosted: Wed Jul 25, 2012 7:46 pm    Post subject: Reply with quote
What about the ability to select faces, and the edges around the faces are where the cut lines are placed ?
PostPosted: Wed Jul 25, 2012 7:48 pm    Post subject: Reply with quote
You can "paint" faces with the G key, and then detach those directly with the Enter key (i.e. it doesn't make cut edges, it just pulls off the G selected region under the mouse pointer).
SuperSheep
PostPosted: Sat Jul 28, 2012 7:45 am    Post subject: Reply with quote
This is perfect how do you deselect polygons in-case you selected the wrong ones ?
Now UV mapping is how I exactly want it Smile
SuperSheep
PostPosted: Sat Jul 28, 2012 7:46 am    Post subject: Reply with quote
The O key did nothing except change to Orthographic view.
GeoffRiley
PostPosted: Sun Jul 29, 2012 11:45 am    Post subject: Reply with quote
It's the '0' - zero - button that is on the edit panel that you need to use, not pressing the letter 'O' keyboard key.
PostPosted: Sun Jul 29, 2012 6:00 pm    Post subject: Reply with quote
Thanks Geoff!
"how do you deselect polygons"
You can find that in the hotkeys here ...
http://www.uvlayout.com/doc/User_Guide:_Hotkeys#Common_Keys
... and have a look at the UVLayout-Marking-Polys movie under the Basic Videos for all the poly marking tips ...
http://www.uvlayout.com/index.php?option=com_wrapper&Itemid=97
SuperSheep
PostPosted: Mon Jul 30, 2012 4:59 pm    Post subject: Reply with quote
headus wrote:
Thanks Geoff!
<<Links blocked until user has been cleared>>
Thanks, and thanks also to Geoff, I would have overlooked, as I never gave those buttons any focus, until now Smile
