SuperSheep
Posted: Sat Jun 23, 2012 7:55 pm Post subject: Edges one at a time ? |
| Can I prevent the C key from selecting edge loops and instead select one edge at a time ? |
oesponda
Posted: Wed Jul 25, 2012 5:00 pm Post subject: |
| Use the "0" button under the Edit section |
Posted: Wed Jul 25, 2012 6:09 pm Post subject: |
Or in the latest release (v2.08.00) you can set it to the new "D" mode. Press and release the C key to select one edge, or press and hold to select the first edge, then drag the mouse pointer to expand the selection in whatever direction you want.
SuperSheep
Posted: Wed Jul 25, 2012 7:46 pm Post subject: |
| headus wrote: | Or in the latest release (v2.08.00) you can set it to the new "D" mode. Press and release the C key to select one edge, or press and hold to select the first edge, then drag the mouse pointer to expand the selection in whatever direction you want.
What about the ability to select faces, and the edges around the faces are where the cut lines are placed ? |
Posted: Wed Jul 25, 2012 7:48 pm Post subject: |
You can "paint" faces with the G key, and then detach those directly with the Enter key (i.e. it doesn't make cut edges, it just pulls off the G selected region under the mouse pointer).
SuperSheep
Posted: Sat Jul 28, 2012 7:45 am Post subject: |
| headus wrote: | You can "paint" faces with the G key, and then detach those directly with the Enter key (i.e. it doesn't make cut edges, it just pulls off the G selected region under the mouse pointer).
This is perfect how do you deselect polygons in-case you selected the wrong ones ?
Now UV mapping is how I exactly want it  |
SuperSheep
Posted: Sat Jul 28, 2012 7:46 am Post subject: |
| oesponda wrote: | | Use the "0" button under the Edit section |
The O key did nothing except change to Orthographic view. |
GeoffRiley
Posted: Sun Jul 29, 2012 11:45 am Post subject: |
| SuperSheep wrote: | | oesponda wrote: | | Use the "0" button under the Edit section |
It's the '0' - zero - button that is on the edit panel that you need to use, not pressing the letter 'O' keyboard key. |
SuperSheep
Posted: Mon Jul 30, 2012 4:59 pm Post subject: |
| headus wrote: | Thanks Geoff!
"how do you deselect polygons"
You can find that in the hotkeys here ...
... and have a look at the UVLayout-Marking-Polys movie under the Basic Videos for all the poly marking tips ...
Thanks, and thanks also to Geoff, I would have overlooked, as I never gave those buttons any focus, until now  |
