GoUVLayout - unofficial GoZ for Zbrush
Norman3D
PostPosted: Fri Feb 03, 2012 11:07 am    Post subject: GoUVLayout - unofficial GoZ for Zbrush Reply with quote
YouTube Video
This small plugin will allow you to send meshes to UVLayout and send them back to Zbrush.
Requirements:
- UVLayout installed. (The plugin should automatically find it)
Installation:
Extract the ZStartup folder and replace it with the one in your Zbrush root folder.
Options:
You'll find the "GoUVLayout" options under the "Zplugin" menu in Zbrush.
Download
PostPosted: Fri Feb 03, 2012 7:17 pm    Post subject: Reply with quote
Thanks for sharing your plugin! We don't use Zbrush here at headus, but I know there's plenty of UVLayout user out there that do.
JPWestmas
PostPosted: Wed Jan 14, 2015 4:55 pm    Post subject: Reply with quote
Works really nice so far. Actually to install you should "merge" the provided ZStartup folder in with the Zbrush 4R6/ ZStartup folder. Just in case anybody gets confused.
Then when inside Zbrush ZPlugs menu and using this plugin for the first time, it will ask you where the UVLayout.exe resides when you press the GoUVLayout Button.
<Ash>
PostPosted: Sun Aug 02, 2015 7:35 am    Post subject: Reply with quote
Hey there, this is actually my very first post here.
The plugins works fine with ZBrush 4 R7 32 bit, however seem to generate an error with ZBrush 4 R7 64 bit (see the attachment below).
I was wondering if there's any workaround for this error (like editing the GoUVLayout.txt file or something similar) or if there's any plan to update the plugin for ZBrush 64 bit.
Many thanks in advance.
Ash
EDIT/UPDATE
I went further trying to resolve the issue. I modified a little the "GoUVLayout.txt" in the ZPlugs64 updating several "paths" from ZPlugs to "ZPlugs64" (as shown below), however I am still getting the same error: there's still something I can't figure out (I guess about the "version"). Sad
I attached also the modified "GoUVLayout.txt" if you want to have a look to it.
Line 9: [VarSet,utilDLLPath,"ZSTARTUP_ZPLUGS64/GoUVLayout/ZFileUtils.lib"],
Line 10: [VarSet,utilDLLPath,"ZSTARTUP_ZPLUGS64/GoUVLayout/ZFileUtils.dll"]
Line 75: [VarSet,UVLAYOUT_PATH_TXT,[FileNameResolvePath,"ZSTARTUP_ZPLUGS64\GoUVLayout\path.txt"]]
Line 76: [VarSet,BAT_PATH,[FileNameResolvePath,"ZSTARTUP_ZPLUGS64\GoUVLayout\bat.bat"]]
Line 82: [VarSet, BAT_1_String, [StrMerge, "reg.exe query HKLM\Software\Classes\uvl.File\shell\open\command /ve > ", [StrFromAsc, 34], "%cd%\ZStartup\Zplugs64\GoUVLayout\version.txt", [StrFromAsc, 34]]]
Line 83: [VarSet, BAT_1_Output, "ZSTARTUP_ZPLUGS64\GoUVLayout\version.txt"]
Line 157: [VarSet, theOBJ, "ZSTARTUP_ZPLUGS64\GoUVLayout\temp.obj"]
Line 158: [VarSet, theMTL, "ZSTARTUP_ZPLUGS64\GoUVLayout\temp.mtl"]
Line 159: [VarSet, theBMP, "ZSTARTUP_ZPLUGS64\GoUVLayout\temp.bmp"]
Line 202: [VarSet, theOut, "ZSTARTUP_ZPLUGS64\GoUVLayout\temp.out"]
Line 203: [VarSet, theCMD, "ZSTARTUP_ZPLUGS64\GoUVLayout\temp.cmd"]
Line 206: [VarSet,fileName,"ZSTARTUP_ZPLUGS64\GoUVLayout\temp.out"]
 Filesize:  63.04 KB
 Viewed:  204218 Time(s)
GoUVLayout.txt
Download
 Filename:  GoUVLayout.txt
 Filesize:  7.34 KB
 Downloaded:  14060 Time(s)
<Ash>
PostPosted: Tue Aug 04, 2015 12:45 am    Post subject: Reply with quote
All right I did another "small" step further, about the version.
I changed the value on this line from 6 to 7:
[VarSet,isMac, [ZBrushInfo,7]]
You can find the latest modified version of the "GoUVLayout.txt" as attaachment below.
Now ZBrush64 don't return the error anymore and I am able to run the application: unfortunately the plugin is not shown in the ZPlugin menu (cause is probably not supported): so still no luck to get it work. Sad
Well I tried as far as I could go: I guess I have to surrender and wait for an answer from Norman. Very Happy
GoUVLayout.txt
Download
 Filesize:  7.34 KB
 Downloaded:  8535 Time(s)
Norman3D
PostPosted: Fri Feb 05, 2016 3:43 pm    Post subject: Reply with quote
Sorry it took months! I never got a notification of there being any new messages on this thread. The issue should be fixed. Simply re-download the file and install the plugin again.
PostPosted: Wed Feb 10, 2016 7:15 pm    Post subject: Reply with quote
Thanks for the update! I'm sure all the ZBrush users will appreciate your support.
dela
PostPosted: Thu Dec 07, 2017 2:10 am    Post subject: Reply with quote
Where does the main txt file go? Isnt very clear, i find the name a bit confusing cause the normal GoZ stuff goes in a shared folder.
Im using it with r8 OSX
Norman3D
PostPosted: Thu Dec 07, 2017 2:14 am    Post subject: Reply with quote
This only works on Windows!
dela
PostPosted: Thu Dec 07, 2017 9:57 am    Post subject: Reply with quote
Okay to bad, i saw you pointing mac in the files but there are no *.lib files. Why is there mac related pointing in these files then, is the source from something different?
PS those *.dll files are they hard to create? perhaps i can help on OSX side
Pendraia
PostPosted: Sun Apr 08, 2018 3:57 pm    Post subject: Reply with quote
Does anyone know if this works with Zbrush 2018?
Thanks
Pen
edited to add...I just successfully sent the demo head to uv layout using this.
Zbrush 2018 on Win 10.
Off to play and see how more complex meshes go...
Daniel Wanket
PostPosted: Wed Jun 26, 2019 11:14 am    Post subject: UV Plugin for Mac ZBrush 2019 Reply with quote
Just wondering if there is a file missing?
keeps saying Zfileutils plugin missing?
