Norman3D
Posted: Fri Feb 03, 2012 11:07 am Post subject: GoUVLayout - unofficial GoZ for Zbrush |
YouTube Video
This small plugin will allow you to send meshes to UVLayout and send them back to Zbrush.
Requirements:
- UVLayout installed. (The plugin should automatically find it)
Installation:
Extract the ZStartup folder and replace it with the one in your Zbrush root folder.
Options:
You'll find the "GoUVLayout" options under the "Zplugin" menu in Zbrush.
Download
Posted: Fri Feb 03, 2012 7:17 pm Post subject: |
Thanks for sharing your plugin! We don't use Zbrush here at headus, but I know there's plenty of UVLayout user out there that do.
JPWestmas
Posted: Wed Jan 14, 2015 4:55 pm Post subject: |
Works really nice so far. Actually to install you should "merge" the provided ZStartup folder in with the Zbrush 4R6/ ZStartup folder. Just in case anybody gets confused.
Then when inside Zbrush ZPlugs menu and using this plugin for the first time, it will ask you where the UVLayout.exe resides when you press the GoUVLayout Button.
<Ash>
Posted: Sun Aug 02, 2015 7:35 am Post subject: |
Hey there, this is actually my very first post here.
The plugins works fine with ZBrush 4 R7 32 bit, however seem to generate an error with ZBrush 4 R7 64 bit (see the attachment below).
I was wondering if there's any workaround for this error (like editing the GoUVLayout.txt file or something similar) or if there's any plan to update the plugin for ZBrush 64 bit.
Many thanks in advance.
Ash
EDIT/UPDATE
I went further trying to resolve the issue. I modified a little the "GoUVLayout.txt" in the ZPlugs64 updating several "paths" from ZPlugs to "ZPlugs64" (as shown below), however I am still getting the same error: there's still something I can't figure out (I guess about the "version").
I attached also the modified "GoUVLayout.txt" if you want to have a look to it.
Line 9: [VarSet,utilDLLPath,"ZSTARTUP_ZPLUGS64/GoUVLayout/ZFileUtils.lib"],
Line 10: [VarSet,utilDLLPath,"ZSTARTUP_ZPLUGS64/GoUVLayout/ZFileUtils.dll"]
Line 75: [VarSet,UVLAYOUT_PATH_TXT,[FileNameResolvePath,"ZSTARTUP_ZPLUGS64\GoUVLayout\path.txt"]]
Line 76: [VarSet,BAT_PATH,[FileNameResolvePath,"ZSTARTUP_ZPLUGS64\GoUVLayout\bat.bat"]]
Line 82: [VarSet, BAT_1_String, [StrMerge, "reg.exe query HKLM\Software\Classes\uvl.File\shell\open\command /ve > ", [StrFromAsc, 34], "%cd%\ZStartup\Zplugs64\GoUVLayout\version.txt", [StrFromAsc, 34]]]
Line 83: [VarSet, BAT_1_Output, "ZSTARTUP_ZPLUGS64\GoUVLayout\version.txt"]
Line 157: [VarSet, theOBJ, "ZSTARTUP_ZPLUGS64\GoUVLayout\temp.obj"]
Line 158: [VarSet, theMTL, "ZSTARTUP_ZPLUGS64\GoUVLayout\temp.mtl"]
Line 159: [VarSet, theBMP, "ZSTARTUP_ZPLUGS64\GoUVLayout\temp.bmp"]
Line 202: [VarSet, theOut, "ZSTARTUP_ZPLUGS64\GoUVLayout\temp.out"]
Line 203: [VarSet, theCMD, "ZSTARTUP_ZPLUGS64\GoUVLayout\temp.cmd"]
Line 206: [VarSet,fileName,"ZSTARTUP_ZPLUGS64\GoUVLayout\temp.out"]
| Description: |
| Filesize: |
63.04 KB |
| Viewed: |
206666 Time(s) |
| Description: |
 Download |
| Filename: |
GoUVLayout.txt |
| Filesize: |
7.34 KB |
| Downloaded: |
14191 Time(s) |
<Ash>
Norman3D
Posted: Fri Feb 05, 2016 3:43 pm Post subject: |
| Sorry it took months! I never got a notification of there being any new messages on this thread. The issue should be fixed. Simply re-download the file and install the plugin again.
Posted: Wed Feb 10, 2016 7:15 pm Post subject: |
Thanks for the update! I'm sure all the ZBrush users will appreciate your support.
dela
Posted: Thu Dec 07, 2017 2:10 am Post subject: |
Where does the main txt file go? Isnt very clear, i find the name a bit confusing cause the normal GoZ stuff goes in a shared folder.
Im using it with r8 OSX
Norman3D
Posted: Thu Dec 07, 2017 2:14 am Post subject: |
| dela wrote: | Where does the main txt file go? Isnt very clear, i find the name a bit confusing cause the normal GoZ stuff goes in a shared folder.
Im using it with r8 OSX |
This only works on Windows!
dela
Posted: Thu Dec 07, 2017 9:57 am Post subject: |
Okay to bad, i saw you pointing mac in the files but there are no *.lib files. Why is there mac related pointing in these files then, is the source from something different?
PS those *.dll files are they hard to create? perhaps i can help on OSX side
Pendraia
Posted: Sun Apr 08, 2018 3:57 pm Post subject: |
Does anyone know if this works with Zbrush 2018?
Thanks
Pen
edited to add...I just successfully sent the demo head to uv layout using this.
Zbrush 2018 on Win 10.
Off to play and see how more complex meshes go...
Daniel Wanket
Posted: Wed Jun 26, 2019 11:14 am Post subject: UV Plugin for Mac ZBrush 2019 |
Just wondering if there is a file missing?
keeps saying Zfileutils plugin missing?
