Multiple uv maps
Slice
PostPosted: Tue Nov 22, 2011 3:57 am    Post subject: Multiple uv maps Reply with quote
Oke!
My question:
I've created a model in Zbrush with multiple subtools( about 20 ) so now I'd like to unwrap everything in UVlayout, is it possible to load multiple .OBJ's at once?
Or, is it possible to create a uvmap of each .OBJ and them merge them together?
Would that not be tricky seeing you need to place your maps inside the assigned area while leaving enough room for the other objects while you don't even know how much space they will take up??
Thank you in advance!
Slice
PostPosted: Wed Nov 23, 2011 5:24 pm    Post subject: Reply with quote
Unfortunately its not possible to load multiple OBJs, so you'll need to use some other modelling app to load the OBJs so you can save them out as one file.
