Slice
Posted: Tue Nov 22, 2011 3:57 am Post subject: Multiple uv maps |
Oke!
My question:
I've created a model in Zbrush with multiple subtools( about 20 ) so now I'd like to unwrap everything in UVlayout, is it possible to load multiple .OBJ's at once?
Or, is it possible to create a uvmap of each .OBJ and them merge them together?
Would that not be tricky seeing you need to place your maps inside the assigned area while leaving enough room for the other objects while you don't even know how much space they will take up??
Thank you in advance!
Slice |
Posted: Wed Nov 23, 2011 5:24 pm Post subject: |
Unfortunately its not possible to load multiple OBJs, so you'll need to use some other modelling app to load the OBJs so you can save them out as one file.
