kmwhitt
Posted: Thu Mar 02, 2017 8:20 pm Post subject: Continuing work on project after reopening. |
| I am relatively new to UVLayout. I wanted to know if it's possible to save a file as a project in order to complete in a separate session. When I close my work and reopen, everything has been dropped into UV edit. Is there a way to have only the shells on which I've worked show in the editor upon reopen? |
Posted: Mon Mar 06, 2017 5:44 pm Post subject: |
If you save as UVL format files, then all your work is preserved (including shell locking, various edge tags etc). Use the Tmp 1 to 5 buttons to quickly save in this format (new ones overwrite old ones), or the E button to save without overwriting.
But also check your Save preferences. Here's the one you want to turn-off ...
| Quote: | Set All UVs on Save
Normally only flattened polys will be saved with UVs. Enabling this preference will force UVLayout to assign a planar projection to any unflattened polys when the mesh is saved out to OBJ files. |
It should be off by default, but maybe got turned on by accident or was on by default in an earlier version?
