bencowellthomas
Posted: Mon Aug 08, 2016 5:42 am Post subject: suggestion / request - restrict selection of straight edges |
Hi there,
Is there any chance of getting the workflow available to both cutting and welding added to the straightening tools ?. ie identify a start and endpoint for an edge loop and select inbetween.
I find myself spending a lot of time untagging edges when using this tool.
It'd be extremely handy if the edge selection was restricted to the uv points that have been identified before hand with the k key. The shift+k would still be fine for a 'flood' style selection.
small but extremely useful if it's possible.
cheers
ben |
Posted: Sun Aug 21, 2016 9:50 pm Post subject: |
Have you tried putting the edge selection into "D" for "drag" mode? This works for I and K and also C etc.
Press and hold the I key on the first edge, then drag the mouse pointer towards the other end, and all edges between will be selected as you move the pointer. You can move the pointer around (while still holding the I key) to select the possible alternate paths when its not an obvious edge loop.
bencowellthomas
Posted: Sat Sep 03, 2016 5:12 am Post subject: |
Thanks Phil, I hadn't used drag mode .. I'll try this out next week and see if it's quicker. I would still vote for the ability to indicate a start and an end to a straight edge as with cut .. it works really nicely and is a really intuitive way to prevent edge selections 'flooding' out to unwanted edges.
thanks
ben |
Deimos
Posted: Thu Oct 27, 2016 9:04 am Post subject: |
| I'd like to second Ben's request. I ran into the same issues that prompted him to start this thread, and will test out Drag mode (didn't know that existed), but having the ability to select endpoints would be amazing. Kind of like using A and S to pin endpoints and then double tapping S to pin everything inbetween. |
