Three65
Posted: Mon Dec 28, 2015 4:08 pm Post subject: Pattern Export at actual size |
| Is there a way to use the export pattern function so that when you save your .eps its at actual size that the "Show Flatten Stats" at. |
Posted: Tue Feb 09, 2016 11:14 pm Post subject: |
The EPS scale is fixed so that the unit red square is 100 x 100 mm (or 283 points). The work-around is to use the Xform panel to set the size of the UV square to 100, then the eps output will match the real flattened dimensions.
I've just fixed this so the EPS output is scaled correctly, and that will be in the next beta or full release.
Posted: Thu Feb 11, 2016 5:34 pm Post subject: |
If you've got a Pro license and are using Windows, then the fix for this is now available in the latest beta release on your uvlayout.com Support Extras page.
Three65
Posted: Mon Mar 28, 2016 11:19 am Post subject: |
| Ive tried the Xform trick but it still doesn't seem to be exporting the .EPS at full size. Also I have 5 UV tiles and the .EPS that Headus is exporting only seems to contain 2 1/2 of the UV tiles in the .EPS The outside boarders are showing up, but the UVs in the middle of the 3rd, along with 4 and 5 are not showing up in the .EPS. Is there any kind of fix for this? |
Posted: Tue Mar 29, 2016 12:17 am Post subject: |
I've just uploaded the official release of v2.09.03, which includes the EPS scaling fix, so you should try that to see if it fixes your problems ...
http://www.headus.com/phpbb/viewtopic.php?p=7441#7441
I did make some multi-tile UVs here and the EPS looked as it should (nothing missing), but if the fixed version doesn't help, email me your UVL file if you like and I'll then be able to work out why its not working for you too.
