kfinla
Posted: Thu Feb 20, 2014 9:45 am Post subject: |
| Awesome, great news. |
Posted: Fri May 30, 2014 6:45 pm Post subject: |
Hello All,
UVLayout v2.08.03 is now available for all users.
- Edit Colors Preference : Allows you to change the different
highlight colors of tagged edges and points, along with the
background and tile and grid lines.
Changes to existing tools:
- Move/Scale/Rotate : Added the option to rotate/scale around
the center of the UV tile that each shell is in.
- Snap/Stack : Can now enable the snapping of UV points to other
UV points.
Bugs fixed:
- Reshape tool : Fixed a fatal error bug.
- cyeatP.exe : Fixed a bug where meshes wouldnt load with a "Cant
open link to cyeatP.exe" error message.
justinmholt
Posted: Fri Jun 20, 2014 9:20 am Post subject: |
| looking forward to trying this out! |
Posted: Thu Jul 17, 2014 12:21 am Post subject: UVLayout v2.08.04 now available |
Hello All,
UVLayout v2.08.04 is now available for Hobbyist and Student version users.
New tools added in this release:
- Symmetry Find : Previously only available in the Professional version of UVLayout, Hobbyist and Student version users now have access to this tool that speeds up the flattening of shapes with mirrored topology.
To enable this, Hobbyist users will need to not only download and install v2.08.04, but they also need to add the updated license key to their keys file, found on their uvlayout.com Support Details page. Student users can just install the update to get the new tool.
Posted: Mon Nov 17, 2014 8:16 pm Post subject: UVLayout v2.08.05 now available |
Hello All,
UVLayout v2.08.05 is now available for all users.
- Pack Rotation : Added the option to rotate shells by smaller
increments (i.e. 45, 30, 15, 10 and 5) when searching for the
best packing solution. The rotation testing will now also use
multiple CPU cores if available. Note: The Pack Rotation tools
are currently only available in the Pro version.
- Pack Wrap : Added new option to pack everything into the 0 to
1 tile but allowing shells to extend over the boundary of the
tile if they wrap around into free space on the opposite side.
You can see an example of this in action at Example:_Pack_Wrap.
- Pack Coverage : Tile coverage feedback now updates continuously,
not just after packing.
Bugs fixed:
- Load options : Clean and Weld are now disabled when running
in Maya plugin mode, as selecting these broke the sending of UVs
back to Maya.
kfinla
Posted: Thu Dec 18, 2014 11:18 am Post subject: |
I'm going from 2.08.02 --> 2.08.05 pro and gotta say there are some awesome updates in there. Stuff I've wished for, for awhile.
ie. Smaller pack rotation testing, constant pack coverage update, snapping.
Great stuff.
*PS. is 2.08.05 OSX 10.10 compatible?.. i see there are newer builds of X11 also. |
Posted: Mon Apr 13, 2015 12:52 am Post subject: UVLayout v2.08.06 now available |
Hello All,
UVLayout v2.08.06 is now available for all users.
Bugs fixed:
- Maya Plugin : Send not working on some systems, tracked down
to variability in the way Maya exports its OBJ files (sometimes
with and sometimes without an .OBJ extension!).
- Plugin Load Loop : When sending particularly large files,
UVLayout would sometimes get into a load loop.
