Maya Error Cannot find procedure"uvlayout_run"
AnimateXYZ
PostPosted: Mon Mar 17, 2014 3:48 pm    Post subject: Maya Error Cannot find procedure"uvlayout_run" Reply with quote
Hi all,
Having an issue running UV Layout Maya plugin. Initially when I installed UVL it was running great. I believe I closed it out incorrectly by clicking the close button on the window rather than the stop button on the UV Layout shelf in Maya. Since then I've been getting this error when I hit the run button. Cannot find procedure"uvlayout_run". I can still use the plugin by going through the Info button and hitting the run uv layout button.
I'm using maya 2014. Anyone have a fix for this?
Edit. I was able to remove the install manually, re install and all is good again.
PostPosted: Mon Mar 17, 2014 6:32 pm    Post subject: Reply with quote
Thanks for the error report and solution.
Maybe just quitting Maya and restarting it might have sorted it out too. Something to try if it happens again.
