Accidentally Hiding UV Sets ?
SuperSheep
PostPosted: Wed Oct 16, 2013 11:01 am    Post subject: Accidentally Hiding UV Sets ? Reply with quote
I seem to be hitting a keyboard short-cut and I couldn't tell you which key, as it just happened. What is occurring is one set of UV is hiding while another is showing, can I switch between UV sets, I need to know what I'm accidentally doing ? Smile
PostPosted: Wed Oct 16, 2013 6:04 pm    Post subject: Reply with quote
Well since there's no UV sets in UVLayout yet, it could be a bug.
Or if you had some shells hidden (using the H menu) then did H-S, that would swap the hide state of all shells. That's the only thing I can think of that might do what you're describing.
SuperSheep
PostPosted: Sat Oct 19, 2013 8:15 am    Post subject: Reply with quote
I was duplicating the UV window, is there a short-cut key for this that I am accidentally hitting ?
PostPosted: Sun Oct 20, 2013 7:24 pm    Post subject: Reply with quote
Well the 1, 2, 3, U and E hotkeys switch between the various viewing modes in the current pane, so that might what you've done.
SuperSheep
PostPosted: Fri Oct 25, 2013 1:06 pm    Post subject: Reply with quote
I'm currently working on a UV set for some reason my extra UV tiles has increased by 10-12 and all my UV islands are gone ? I can show a screen shot if needed ?
PostPosted: Fri Oct 25, 2013 5:48 pm    Post subject: Reply with quote
Yes, pics are good! But maybe my answers to your other Packing question will help here.
SuperSheep
PostPosted: Fri Oct 25, 2013 6:57 pm    Post subject: Reply with quote
There is only one shell visible, the 1,2,3, U & E keys won't bring back the other shells ?
How come there are so many tiles ?
PostPosted: Fri Oct 25, 2013 7:19 pm    Post subject: Reply with quote
Maybe the rest of them are hidden? Have your tried H-U?
SuperSheep
PostPosted: Fri Oct 25, 2013 7:49 pm    Post subject: Reply with quote
It was U.
Thank you so much; and for the quick reply as well Smile
