UV Shell Boxes and Sizing UV Shells
SuperSheep
PostPosted: Thu Jan 17, 2013 6:48 am    Post subject: UV Shell Boxes and Sizing UV Shells Reply with quote
When I re-size a UV box with shells within, the shells don't scale to the size of the ' UV box' all that occurs is the 'packing' progress bar is shown. The end results are not a scaled 'box' with all the shells scaled as well, rather the 'UV box' is the same size as it was previously ?
One other thing, I want one UV island to match the size of another. When I check the size of one UV shell, suppose it's 88.26, and I select another UV shell it is the same size (88.26) how can it be, unless I can scale that accurately with my own eye ? Smile
PostPosted: Thu Jan 17, 2013 5:28 pm    Post subject: Re: UV Shell Boxes and Sizing UV Shells Reply with quote
"When I re-size a UV box with shells within, the shells don't scale to the size of the ' UV box' all that occurs is the 'packing' progress bar is shown. The end results are not a scaled 'box' with all the shells scaled as well, rather the 'UV box' is the same size as it was previously ?"
Yes, that's whats supposed to happen. Moving the box corner handles just adjusts the aspect ratio of that packing ground (i.e. whether you want them arrange vertically or horizontally or anywhere between). If you want to scale the entire group, use Space-RMB on one of the corner handles, the same way you'd scale an individual shell.
"One other thing, I want one UV island to match the size of another."
Doing it by eye is probably the easiest way. If you want it *exact* though, LMB select the two shells and click on the "&" button after "Fit To Sqr" in the Move/Scale/Rotate panel. That will scale both shells so they fit exactly within the UV red square, but then you'll need to resize them both (Space-RMB again) to get them back to a normal size.
SuperSheep
PostPosted: Fri Jan 18, 2013 6:57 am    Post subject: Re: UV Shell Boxes and Sizing UV Shells Reply with quote
When I select the two islands that I want to have the exact size, all of my islands and 'UV boxes' grow to the size of the UV space (0-1) overlapping each other after 'FitToSqr', I doubt this is right ? If I continue with the '&' key all I get is all my islands overlapping with the 'red' color ?
PostPosted: Fri Jan 18, 2013 6:16 pm    Post subject: Reply with quote
Sorry, my mistake, I didn't mean that you click the "Fit to Sqr" button first, I just meant for you to click the "&" button on that row only.
SuperSheep
PostPosted: Fri Jan 18, 2013 7:41 pm    Post subject: Reply with quote
Thanks. Why is it when you do an operation like this the other islands turn red ?
PostPosted: Sun Jan 20, 2013 11:58 pm    Post subject: Reply with quote
Ahhh, yes, I forgot about that! Its meant to do that, but that's because that tools is really used for other things, not exactly what you want.
Maybe a better way then is to look at the dimensions of the two shells, then use a calculator to work out the scaling factors, then you can enter those into the U and V values for the blue Scale button. That way you can scale the selected shell exactly so it matches the size of the other one.
SuperSheep
PostPosted: Mon Jan 21, 2013 5:48 pm    Post subject: Reply with quote
The size of two closely identical islands are always the same size when I check Sad I'll come up with something Smile
PostPosted: Mon Jan 21, 2013 5:50 pm    Post subject: Reply with quote
Could you email me a picture of that? If I understand a bit better what your ultimate goal is, I might be able to come up with a smarter solution.
SuperSheep
PostPosted: Wed Jan 23, 2013 9:20 pm    Post subject: Reply with quote
Unless they are the exact size ?
What other things ? Smile
PostPosted: Mon Jul 22, 2013 6:37 pm    Post subject: Reply with quote
The Size value you see there is the dimensions of the red UV square; its doesn't show the size of the selected shell.
Open up the "Pattern" tools and tick the "Show Flattened Stats" box. That will write the width and height of every flattened shell into the UV view.
