cutting and welding edges in 3D mode
333DDD
PostPosted: Fri May 17, 2013 10:39 pm    Post subject: cutting and welding edges in 3D mode Reply with quote
In the totorial video 'welding shells', you have a section where you cut edges you select in 3D mode. I cant do this, I cant select edges hitting 'c' or 'w'. Has this been taken out of UVLayout? Or is there another way of doing it?
Cheers
333DDD
PostPosted: Fri May 17, 2013 11:11 pm    Post subject: Reply with quote
nevermind I figured it out. I had imported with 'new' selected and wiped my UV's. Imported again and all shells are dropped to UV mode and now 3D mode cut and weld selection does it like it always has:)
I fkn LOVE this program thank you so much:)
PostPosted: Sun May 19, 2013 6:01 pm    Post subject: Reply with quote
Thanks for the update :) We made the "Edit" option the default because in the early says it was on "New" and there were lots of "I loaded my mesh but there's no UVs" type questions.
