Again, libXm.so.4 problem when launch uvlayout.
zhimama
PostPosted: Thu Apr 18, 2013 1:19 am    Post subject: Again, libXm.so.4 problem when launch uvlayout. Reply with quote
Hi there,
I know it is not a new issue about motif libraries. I tied to dig up those old topics in the forum but somehow I still can't manage it to work. Also I have several things needed to point out.
Here is what I do:
1) I'm using Linux Centos 6.3 64bit.
2) I opened the bashrc file and added three lines below:
export HEADUS_HOME=/usr/local/uvlayout-demo
export PATH=$HEADUS_HOME/bin:$PATH
export LD_LIBRARY_PATH=$HEADUS_HOME/lib
3) Put compressed uvlayout tgz file into /usr/local/
I ran the command copied from this website shown below:
tar xvfoz uvlayout-demo.tgz --directory=$HEADUS_HOME/..
(don't know if there is a typo or something, the command doesn't work for me so I used the following one to decompress the tgz file and installed it in /use/local/ )
tar -zxvf filename.tgz
4) Once the installation is done. I opened a new shell and typed headus. It shows LibXm.so.4 can not be opened.... (something like that)
5) I downloaded this file ( headus-missing-libs.64.tgz) provided by the uvlayout office website, and copied those two files into usr/local/uvlayout-demo/lib/ folder.
(that's the reason I added the third command in the bashrc file shown in step 1).
6) It is still not working.
I need help form someone who can check if there is something I missed ? or which step I did things wrong.
Help, please.
jinjin
PostPosted: Thu Apr 18, 2013 10:20 am    Post subject: Reply with quote
So disappointed about the installation issue. Can't find solution.
PostPosted: Thu Apr 18, 2013 7:52 pm    Post subject: Reply with quote
Maybe you'll have more success with a wrapper script. There's an example of one here ...
http://www.uvlayout.com/doc/Installation_Guide:_Linux#Wrapper_Script
A script like that will guarantee that the variables are being set correctly, you then run the script to start UVLayout.
zhimama
PostPosted: Thu Apr 18, 2013 10:31 pm    Post subject: Reply with quote
Here is the error message when I tried to launch uvlayout in terminal:
cysliceP: error while loading shared libraries: libXm.so.4: cannot open shared object file: No such file or directory
The last try I had was to yum install libXm.so.4
However, it still shows me the same message above even I installed libXm.so.4 series files.
Ai ~ I have tried every way I could possible think but still no luck.
PostPosted: Thu Apr 18, 2013 10:40 pm    Post subject: Reply with quote
Is that with the wrapper script? Call the wrapper script something like "run-uvlayout", and then you'd type that into the shell window, not running uvlayout directly.
