Posted: Mon Apr 15, 2013 3:50 am Post subject: 8K repaint please |
The repaint option is limited to 4k. Could we please have it extended to 8K?
Is it possible to change this setting somehow without waiting for a new build/release?
The 4k limitation seems to be throughout the program..
Cheers |
Posted: Mon Apr 15, 2013 6:51 pm Post subject: |
In my current dev version, its limited to 8k in the GUI. I dont think I did that recently, so the same 8k limit might have made its way into the latest beta releases.
But actually that limit is just in the GUI, not in the code that does the real work. You may be able to trick it by typing the value you want into the field (e.g. "8k"), then click the Repaint button.
Posted: Mon Apr 15, 2013 10:42 pm Post subject: Limit |
Yes I tried that but it changes straight to 4k |
Posted: Mon Apr 15, 2013 10:43 pm Post subject: Limit |
Posted: Mon Apr 15, 2013 11:33 pm Post subject: |
Don't touch the Enter key ... just type in "8k" and then click the Repaint Button.
If you still cant get that to work, try using the alternate value settings. By that I mean "=" or "*". If you input map is 8k, then typing "=" into that field means that the output map will be the same size. If the input is 4k for example, then typing "*2" into that field should give you an 8k map.
