Help ! uv layout can't not setup on windows 8
naktim
PostPosted: Tue Oct 30, 2012 7:08 am    Post subject: Help ! uv layout can't not setup on windows 8 Reply with quote
Help!!!!!!!!!!!!!! I need that!! asap!!!
please!!!!!!!!!!!!!
PostPosted: Tue Oct 30, 2012 6:09 pm    Post subject: Reply with quote
Unfortunately, we don't currently support Windows 8. So in the short term at least, you'll need to borrow a Windows 7, Vista or XP system.
PostPosted: Thu Nov 01, 2012 11:51 pm    Post subject: Reply with quote
I just tested UVLayout on a Windows 8 PC and it seems to work fine. The only hurdle was during the initial install, where Windows said something along the lines of "Can't install unknown application", but if you click the "More Information" link, it allows you to install anyway.
Did you have the same problem, or was it something else?
umblefugly
PostPosted: Thu Nov 08, 2012 5:23 pm    Post subject: Reply with quote
UVLayout Professional v2.08.01g seemed to install perfectly on our new ASUS Laptop running Windows 8 64 Bit. Only annoyance I dealt with getting it setup was turning off UAC. (I usually do that anyway).
Cheers
PostPosted: Thu Nov 08, 2012 5:59 pm    Post subject: Reply with quote
Great, thanks for the info! Its looking then like UVLayout is fine under Win 8.
umblefugly
PostPosted: Wed Nov 14, 2012 9:52 am    Post subject: Reply with quote
I had to do it because I recently had surgery so I was down for a bit, but I was able to get my mapping job done with absolutely no issues. Smile
valurik
PostPosted: Wed Dec 24, 2014 8:48 am    Post subject: Reply with quote
Have encountered strange issues. Not to say it's really bothering but it's there.
Under Win8 Layout works slower(((
Search for similar geometry when Copy UV's takes a lot more time, On any geometry simple or complicated. Mybe it's just my problem.
But on the same machine with win7 worked just perfect.
PostPosted: Mon Jan 05, 2015 7:00 pm    Post subject: Reply with quote
Have a look at this in the online docs ...
http://www.uvlayout.com/doc/Installation_Guide:_Windows#Known_Problems
Changing your OpenGL preference might help.
