Save Symmetry in UVL
dustinbrown
PostPosted: Tue Jul 24, 2012 8:38 am    Post subject: Save Symmetry in UVL Reply with quote
Is there a way to get Headus to store your symmetry data if you save using the UVL format? On complex models it can be a pain to have to go back and retag all your symmetry edges.
If it can't currently do it, I think it would make a great feature.
PostPosted: Tue Jul 24, 2012 6:11 pm    Post subject: Reply with quote
It should be storing the symmetry data already. The thing that may be catching you out is that when you first load a UVL file, the symmetry is turned off by default. But if you then click the Symmetry On button, the previous symmetry setup should appear.
