Madin
Posted: Sun May 06, 2012 3:35 am Post subject: Load button and other issues. |
Pressing the load button in the v2.08 GUI does not bring up the file directory for me.
Also if I have loaded a tmp.uvl file. Now that there is no update button, I have no way of using this uvl to update the original .obj (I had loaded the .obj has a 'new' file, then used the temp quick save buttons).
Pressing the save button also does nothing.
Any ideas?
edit: The 'Load' & 'Save' buttons do nothing. The temp save buttons do work and save a .uvl file. The rest of the program works has expected.
I was running a demo version & I use Windows XP home 32bit.
I had exported an .obj file from 3D Max 9 for editing in UVLayout, which opened fine using the drag and drop method, but I could only use the temp save to save progress because the save button did nothing to the original file. |
Posted: Sun May 06, 2012 7:27 pm Post subject: |
Oops, not sure what happened there ... I'm sure I had tested the Demo version before uploading.
Anyway, I've fixed the problem and have uploaded a new installer to the Demo download page. The Load and Save buttons should be work, and the old "Update" button should appear when its needed.
Madin
Posted: Sun May 06, 2012 9:13 pm Post subject: |
| headus wrote: | Oops, not sure what happened there ... I'm sure I had tested the Demo version before uploading.
Thank you for your fast response!  |
