Flatten all cuts automatically?
slsl
PostPosted: Wed Dec 07, 2011 12:51 pm    Post subject: Flatten all cuts automatically? Reply with quote
Hi, is there a way to automatically flatten out all my cuts on the UV editor... i have like 200 cuts for my object(a tree), and i dont want to press F to each cuts.. is there a way to autmatically flatten it out... Thanks!!!!!
PostPosted: Wed Dec 07, 2011 6:20 pm    Post subject: Reply with quote
If you're in the Ed view, you can drop everything to UV space by aiming the mouse pointer at clear air and typing 'D'; you can then click'n'drag the left mouse button around the shells you want dropped.
If you then switch to the UV view, aim the pointer again at clear air and type 'F'; you'll then be able to draw a box around the shells you want flattened.
That just squashes them though, so next you'd click the Optimize "Run For" button, and that flattens all shell out as if you were holding 'F' over them.
slsl
PostPosted: Thu Dec 08, 2011 6:10 am    Post subject: Reply with quote
Thanks!.. work great!!!!
