stezza
Posted: Fri Aug 05, 2011 5:29 am Post subject: Maya 2012 send mesh not working |
I seem to be getting an issue with the send mesh button.
I used to be able to use the maya script in 2012 but all of a sudden it has stoppped working.
I can run uvlayout from the shelf button and stop it but I just cant load using the send mesh button.
OBJexport is turned on in the plugins.
I also noticed that the info panel cannot be moved around so just sits in front of the viewport until you close it.
I can export as obj and do it the long way round no probs but kind of miss the send mesh feature.
here is some errors from the script editor. simple poly object with default maya lambert applied.
// Error: No object matches name: .color //
// Error: No object matches name: .ambientColor //
// Error: No object matches name: .normalCamera //
Any ideas? |
stezza
Posted: Fri Aug 05, 2011 5:32 am Post subject: ammendment |
I can move the info panel around just needed to select the very edge. |
