unknown fatal error detected . exiting
sunnydanieljoseph
PostPosted: Tue Jul 12, 2011 1:46 am    Post subject: unknown fatal error detected . exiting Reply with quote
Hi
I was using HEADUS for a long time
but after a 6 month break, i got back to the work flow ,
as i press C to cut the edges i get this pop up & i have to exit headus
plz help (image attached below)
using 64 bit XP OS
on ati card
quad core phenom pross 2.8g
PostPosted: Tue Jul 12, 2011 4:22 pm    Post subject: Reply with quote
Which version of UVLayout are you using? You can get the latest release from your uvlayout.com Support Download page.
muze3d
PostPosted: Fri Oct 14, 2011 8:16 am    Post subject: same problem Reply with quote
I'm having the same problem. In the Ed window, i can't even pick anything because i get this error. It happens when i hit the "G" button.
My version of: v2.06.03 - Hobbyist
PostPosted: Fri Oct 14, 2011 4:21 pm    Post subject: Reply with quote
That version is over 18 months old, so the problem you're experiencing could very well have been fixed already. If you login to your uvlayout.com account, you can get the latest releases from the Support Download page.
