After load OBJ, Edit btn turn to grey...
gimong910
PostPosted: Thu Apr 14, 2011 11:59 pm    Post subject: After load OBJ, Edit btn turn to grey... Reply with quote
Hi. I am a begginer of UVlayout.
When I re-opened my obj file that I've already work on UVmap before, I found the EDIT btn is disable. (See the image)
How can I continue my uv work?
I didn't check any of loading option. ( clean, weld UV...)
Please give me some advice.
Thank you in advance.
PostPosted: Fri Apr 15, 2011 12:38 am    Post subject: Reply with quote
The "Ed" button is only enabled when you have polys that have no UVs. If its greyed out, then all your polys have been flattened (i.e. they have UVs now) so you switch to the UV view to see and edit them.
If you had only partially flattened the mesh before saving it, whats most likely happened is that default UVs have been assigned to the unflattened polys. This is the "Set All UVs on Save" toggle under the Save preferences.
If you want to delete those default UVs, go to the UV view and use the Shift-D key to "undrop" all the shells that are in the negative tile (i.e. the UV tile to the left and down from the red square). You will then be able to edit those shells back in the Ed view again.
gimong910
PostPosted: Fri Apr 15, 2011 1:06 am    Post subject: Reply with quote
WOW Thank you so much! Phil!!
I was stressing out of the issue for a hour.
Nice of your advice!
