UVLayout file browser doesn't support lage filesystems
swiss-se
PostPosted: Tue Jan 04, 2011 6:21 am    Post subject: UVLayout file browser doesn't support lage filesystems Reply with quote
Hello, we've found that the UVLayout file browser will fail to read the contents of large filesystems, i.e. filesystems where contain entries where either the inode or offset exceeds 32 bits.
The file browser returns no contents, and the console logs "uvlayoutP: scandir: num_files=-1: Value too large for defined data type".
The system call failing is:
getdents(6, 0x8b919c0, 32768) = -1 EOVERFLOW (Value too large for defined data type)
This is probably due to calling readdir instead of readdir64.
PostPosted: Tue Jan 04, 2011 7:58 pm    Post subject: Reply with quote
Excellent debugging!
It looks like the getdents() call writes into a structure that uses longs for the inode number of the returned entry, so my best guess is that's where the problem is. On the usual 32bit build of UVLayout, that would be limited to 32bit inode numbers.
A 64bit build of UVLayout might be the answer in that case, and there's one of those available on your uvlayout.com Support Extras page. Its not the current release, but if it fixes your problem, I can easily build the latest as 64bit.
SLI_Fallen
PostPosted: Wed Jan 05, 2011 4:50 am    Post subject: Reply with quote
I dont know how much time is involved with this but IMO it would be nice to have both 32bit and 64 bit builds available for registered users on the support page when they are released. Just a thought. Wink
PostPosted: Wed Jan 05, 2011 7:30 pm    Post subject: Reply with quote
Thanks for the thought :) But there's a few reasons why the 64bit version is hidden away like that ...
- Because the meshes that you might ever load into UVLayout are relatively small (i.e. tens of thousands or polys max, not tens of millions) then 32bit builds are perfectly fine. You are never going to get near the 3Gb or so per-process memory limit that 32bit apps have.
- There's some issues with the USB dongle driver for the 64bit builds of UVLayout, which pretty much restricts its use to those with floating licenses.
- Currently I can only build 64bit versions under Linux, and supporting 64bit for Windows and OS X too would be extra work to set up for little or no pay-off at this point in time.
SLI_Fallen
PostPosted: Thu Jan 06, 2011 2:53 am    Post subject: Reply with quote
This is one reason I am not a computer programmer! (I do hardware) Very Happy
(Plus i'm using Windows)
Very simple and clear explanation Phil, Thanks!
swiss-se
PostPosted: Thu Jan 06, 2011 3:57 am    Post subject: Reply with quote
Hi Phil, I can confirm the 64-bit version does not have this issue. It would be great if you could create a current 64-bit build for us, too. Thanks!
PostPosted: Fri Jan 07, 2011 6:16 pm    Post subject: Reply with quote
Done! There's now a 64bit build of the latest 2.07.00 release up on the Support Extras page.
